Показано с 1 по 30 из 33
Тема: epc 4 problem help
  1. epc 4 problem help
    HTTP Status 500 problem wolves, but I'm setup to tell you we EPC 4 picture to better understand tanks turkey ıstanbul
  2. Монстр астраколхозинга Заслуженный флудер CoDeMasteR Астранафт Аватар для CoDeMasteR
    Москва ЗАО
     0реlац т0й
    It seems you have working Apache web server but Transbase database software had problems during startup process.
    Checklist:
    1. "SBS_GM_TRANSBASE" service is running
    you can check this in My Computer -> Manage -> Services
    2. Try re-configure Transbase databases
    in command line execute:
    Код:
    java -jar "C:\Program Files\Snap-on Business Solutions\Global EPC\GM\Configurator\Configurator.jar"
    ...and check error messages
    Attach screenshot of your HTTP 500 error screen here.
    Москва ЗАО
     0реlац т0й
    [img]http://img7.**************/img7/2122/ddimage0.jpg[/img]
    here is the screenshots. i have checked the services they are working
    is there a special action to doo while installation. i thave tried to install epc4 several pc (vista, xp sp3, xp sp2..) but can not run
    You haven't Transbase read-write database successfully installed and/or registered with transbase. As shown on your screenshot defective database is "MACE_rw". Carry out step 2 from my 1st post to restore correct Transbase database registration.
    Also you can intsall EPC4 on WinXP SP3 from this DVD image http://torrents.ru/forum/viewtopic.php?t=1801610 .
    To avoid copy protection warning use Alcohol 52% with RMPS and bad blocks emulation turned on.
  4. [img]http://img38.**************/img38/5589/ddimage1.jpg[/img]
  5. Монстр астраколхозинга Заслуженный флудер CoDeMasteR Астранафт Аватар для CoDeMasteR
    Москва ЗАО
     0реlац т0й
    GOLD MASTER
    I don't understand your Turkish windows user interface yet
    EPC4 Apache Service is named "SBS_GM_APACHE". "Apache2" service belongs to different software product installed on your PC.
    EPC4 built on two services: Apache Web server and Transbase database engine. Services are connected via JDBC driver. If you see "HTTP 500" error with words "Transbase" and "exception" your Apache is running fine. The problem is in Transbase.
    I have successfully installed EPC4 published by GM in March 2009. What version of EPC4 you have?
  6. my Opel.EPC.4.2009-04 I have my computer problem "HTTP 500" error
    my turkeyelectronic@windowslive.com
    you talk
  7. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Эээ... Это вы тут ваще о чем...?
    Если я правильно понял, то проще снести кривую ось и поставить по новой. Или в виртуалке.
  8. friends picture to tell you epc4 2009.04
  9. Монстр астраколхозинга Заслуженный флудер CoDeMasteR Астранафт Аватар для CoDeMasteR
    Москва ЗАО
     0реlац т0й
    ...да вот решили английский вспомнить
    Насколько я понял, это дистрибутив имеет глюк в исталяторе и не региструрует установленые базы. EPC4 запускается, но свою базу не видет.
  10. to establish English as I EPC 4
  11. Монстр астраколхозинга Заслуженный флудер CoDeMasteR Астранафт Аватар для CoDeMasteR
    Москва ЗАО
     0реlац т0й
    I have older EPC4 version
    Where did you get 04/2009 release?
  12. http://rapidshare.com/files/245445291/Opel_1_.EPC.4.2009-04.rar.html[/url]
    BitTorrent dowloand EPC.4.2009-04
  13. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Лэт хим кик ит аут энд даунлоат фром торренттс ру. Зис пакедж из фули воркэбл, ит воз тестед бай ми. Йопт...
  14. Монстр астраколхозинга Заслуженный флудер CoDeMasteR Астранафт Аватар для CoDeMasteR
    Москва ЗАО
     0реlац т0й
    GOLD MASTER
    thanx
    I already downloading this EPC4 version from thepiratebay.org I'll try to install it later and produce step-by-step solution.
    Добавлено спустя 3 минуты 7 секунд:
    жжошь
    У GOLD MASTER посвежее и потолще будет
  15. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Фигли толку от "посвежее", если не работает? К тому же куда уж толще - 03.2009 и так 5 гигтар весит.
    Москва ЗАО
     0реlац т0й
    Сдается мне что я знаю как заставить его заработать
    Скачается через 6 часов (мало сидов), вот и посмотрим че за зверь?...
  17. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Ну кто бы в тебе сомневался. Ага, расскажешь потом.
  18. Цитата Сообщение от CoDeMasteR
  19. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Неее, это ни фига не толще.
    GOLD MASTER
    Don`t you want to download 03.2009? The difference is minimal but it`s workable...
  20. my epc 03.2009 ok no problem my epc 4 use but epc 4 my problem http status 500- error why problem you my To help, please epc 4 picture to explain
    Добавлено спустя 2 минуты 6 секунд:
    epc 4 2009.04 saab opel chevrolet ok but
  21. Местный Бакалавр АСТРАномии Serg-dracon на верном пути Аватар для Serg-dracon
    Opel Astra Sedan 1.6 MT Magna Red (Brilliant) Cosmo +Би Ксенон+СDC40 Opera+ESP+сид по 6 полож,заводской БК....
    Заказана в Атлант-М Балтика
    Москва ЗАО
     0реlац т0й
    Скачал, поставил... те же яйца, вид сбоку
    Ставится так же, работает так же, и вообще эта таже сборка от 12.02.2009
  23. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    CoDeMasteR
    А теперь переведи товарищу.
  24. helppppppp =(=(=(
  25. Местный Заслуженный Астравод misha_kr на верном пути Аватар для misha_kr
    ВнутриМКАДе
    Я поставил себе ЕРС 12-2009
    у меня следующая бага, вместо некоторых руссикх слов краказябры.
    До этого стояла 03-2009 такого не было. Винда ХР. Никто не сталкивался?
    Была Astra 5dr HB 1.6 5MT Enjoy
    Subaru Outback B14
  26. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    misha_kr
    Тоже поставил, тоже такое есть, но только в этом месте, думаю - это не повод для расстройства.
  27. Местный Опытный Астравод Arthur на верном пути Аватар для Arthur
     *682** 197
    а что это хоть такое?
    Astra J 1.6T AT 5D white cosmo
    была 1.8 MT GTC IDS+ Синий *405** 199
  28. Местный Гигант мысли VerSerj Астранафт Аватар для VerSerj
     *582** 197
    Arthur
    Родной GM-овский электронный каталог запчастей и база данных по комплектациям машин, причем каждой конкретной, пробивается по VIN-у.
  29. Местный Заслуженный Астравод misha_kr на верном пути Аватар для misha_kr
    ВнутриМКАДе
    VerSerj
    Просто некрассиво как-то))
    Кстати она весить меньше чем 03-2009(
    Subaru Outback B14
