chinaobdii
launch X431 diagun
10.05.2013 в 11:07 (2589 Показов)
Do you know how to use[URL="http://www.**********.com/index.php?id_product=8&controller=product"] launch x431 diagun [/URL]? let me show you .
Plug in x431 diagun main unit and press power key on the main board, tips for calibrating the touch screen will be displayed, press hotkey to begin calibrating, see chapter calibrate touch screen for operation procedure, if you are not willing to calibrate ,please wait and enter into star up interface, see figure on the left ,launch x-431 diagun when you press power key for 2 seconds to turn off the main unit.
X431diagun there is taskbar at the bottom of each operation interface of x-431diagun
,and includes serveral icons, as show in the left figure, their functions are described as below. Start button the same as the windows, click it with stylus to pop up start menu, which includes the main function of diagun scanner, see chapter 3 and 4 for details
X431diagun scanner when diagnostic vehicles, it have condition for test, one is turn on the vehicles, the second is the voltage of vehicle bettery should be 3-37v,the rate voltage of the x-431diagun scanner is 12/24v,the throttle should be in the closed position, the lgnition timing and idle speed should be within specification range, water and transmission oil temperature is in normal working range, diagun tool need to put the CF card in the CF card slot,,keep the face labeled upside upward, and make sure the card is fully seated.
x431diagun tool if the power supply on vehicle diagnostic socket is insufficient or the power pin is damaged , you can get the power from the following ways
Галерея
